Pixie, Smart Hose Faucet Timer
Price: $119.00
Model:
Threads:
In Stock
Shipping Policy
Quantity
Efficient solar panel
A 1-day solar charge supports 1 week of operation
Replaceable battery
Battery can be removed and charged from a USB port
Multi-color LED light
Shows the status of the timer and battery
Multi-function button
Manually water without disturbing the programmed schedule.
Wireless connection
Connects with Wi-Fi stably with enhanced 2.4G antenna
Rain/dust resistant
Designed for outdoor use with cold water
Model: Pixie-1 Technical Specifications – Dimensions: 6.5 X 4.3 X 1.9 (inches) – Weight: 16 oz / 450 g – Box contains: smart hose faucet timer, battery, water filter, charging cable, quick installation guide – WiFi: 802.11 N, 2.4Ghz, US / Japan / EU – Operating temperature range :32° to 122℉ / 0℃ to 50℃ – Water pressure: 0.02MPa to 0.8Mpa – Threads: US standard 3/4” GHT (Garden Hose Thread) Warranty – 2-year limited hardware warranty
user_manual_pixie.pdf
It is 3/4” GHT (Garden Hose Thread).
WiFi Connection
Pixie needs Wi-Fi to connect to the internet. There are two frequency bands used for Wi-Fi communication: 2.4GHz and 5GHz. Most modern routers can broadcast on both bands. Pixie only uses the 2.4GHz band because the 2.4GHz has a farther range than the 5GHz. To make sure Pixie is within your Wi-Fi network’s range, the easiest way is to use your phone to test. If your phone is able to detect the WiFi signal, Pixie should be able to connect at the same location.
The timer will continue to execute the pre-loaded schedules for up to one month.
Overall rating: 1/5
2021-03-04 14:42:37 UTC
The Produkt is Not arrive the destination
